Is it possible to use a protocol that is not in use as filter in dashboards?
Solved2.39K views8th March 2023Dashboards
7
Stijn Declerck [SLC] [DevOps Advocate]824 7th March 2023 2 Comments
In the Dashboards module, can you use a protocol that is not in use for filtering data?
The protocol is installed on the DMA.
I want to put a filter on a dropdown of all elements to only show the elements running that specific protocol. The value chosen in the dropdown determines of of which element the data is shown. The system is rather dynamic, elements are often deleted/created. So it is possible, like now, that there are no elements running the protocol and the dropdown doesn't have any values.
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 8th March 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 7th March 2023
Can you elaborate a bit more on the use case? Where do you want to use this protocol filter?
Stijn Declerck [SLC] [DevOps Advocate] commented 7th March 2023
I have updated the question.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 8th March 2023 1 Comment
Hi Stijn,
We indeed only show the names (and versions) of protocols that are effectively used in the DMS. This is done to avoid having too many (unused) items in the list, so the user can focus on protocols that matter.
Potentially we could make it available to show all protocols (and versions), but this would require a software change. Feel free to create a new feature suggestion or task for this.
As a side note, it will be possible in the future to have the results of a GQI query in a drop down. With this you could feed elements to your state component as well.
Stijn Declerck [SLC] [DevOps Advocate] Posted new comment 8th March 2023
Stijn Declerck [SLC] [DevOps Advocate] commented 8th March 2023
Thanks for your reply!
