Is it possible to run multiple EPM solutions on a DMS?
Solved1.74K views25th August 2021EPM
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 24th August 2021 0 Comments
I want to set up an Agent with the idea to showcase different EPM integrations that we did. Is it possible to run multiple EPM solutions on a DMS?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 25th August 2021
Maarten De Groote [SLC] [DevOps Member]20 Posted 24th August 2021 0 Comments
You can setup multiple EPM solutions on a DMS, but only one Front end manager will be linked to the topology tab in the sidebar. If you want to switch between different managers you can stop the other managers.
Martijn Vanallemeersch [SLC] [DevOps Member]953 Posted 24th August 2021 0 Comments
Hi Jens,
Currently this is indeed not possible (or not in a user friendly manner). This will be tackled in a future release of EPM (I’ll inform you when this becomes available).
KR
Martijn Vanallemeersch [SLC] [DevOps Member] Answered question 24th August 2021
