Is it possible to monitor the OS of a DMA with SNMP?
Solved2.71K views22nd July 2020SLSNMPAgent SNMP SNMP traps
Jamie Stutz [SLC] [DevOps Member]1.18K 21st July 2020 0 Comments
The root of the question is really about can we have both the Windows SNMP and the SLSNMPAgent services running at the same time? If so, what configuration changes (if any) would need to be made to accommodate this. We do have some elements that receive updates from devices via trap notifications. Would those also need to have some configuration updates?
Jamie Stutz [SLC] [DevOps Member] Selected answer as best 22nd July 2020
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 21st July 2020 1 Comment
Hi James,
It is possible to run both services (Windows SNMP and SLSNMPAgent) on different ports:
  • For Windows SNMP, you can change the default port in the following file:
%systemroot%\system32\drivers\etc\services
  • For SLSNMPAgent, you can change the default port in the DataMiner.xml file
More information can be found in DataMiner Help (Changing SNMP ports).
Jamie Stutz [SLC] [DevOps Member] Posted new comment 22nd July 2020
Jamie Stutz [SLC] [DevOps Member] commented 22nd July 2020
Thanks Miguel!
