Is it possible to have failover pair for a selective number of DMA’s in a DMS environment?
Solved2.34K views30th August 2023Failover
Naveendran Murthy [SLC] [DevOps Member]226 28th August 2023 0 Comments
In a DMS environment which has 10 main DMA's, would it be possible to have failover-pair for just 3 of them? (The other 7 stays without a failover-pair)
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th August 2023
Danielle Falcone [SLC] [DevOps Advocate]1.49K Posted 28th August 2023 0 Comments
Hello Naveendran,
Yes, it is possible, the failover works individually.
To add a failover pair you must add a new DMA, please follow: Preparing the two DataMiner Agents | DataMiner Docs
kind Regards
