Is it possible to get Parameters for multiple Elements using Dataminer API in a single call?
Solved1.10K views8th August 2023
Kristopher Brookshire [DevOps Member]220 28th July 2023 0 Comments
I am trying to get a few parameters from 200+ element using the Dataminer API. Is there a way to do this without have to use GetParameters for each element?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th August 2023
Koen Cools [SLC] [DevOps Member]331 Posted 31st July 2023 0 Comments
Hi Kristopher,
I verified our documentation and indeed, I don't see immediately a method to get a few parameters of multiple elements.
Maybe it's an option to develop and use an user-defined API?
Regards, Koen
