Is it possible to export trending to CSV via an automation script or another method ?
Solved716 views20th August 2025real time trending trending data
Alexandre Bonnet [DevOps Advocate]453 4th June 2025 0 Comments
Hello Dojo,
I was able to export trending data to csv via this method, but since we need to do this action for multiple trends on a daily basis.
https://docs.dataminer.services/user-guide/Basic_Functionality/Trending/Working_with_trend_graphs/Exporting_a_trend_graph.html?q=exporting%20a%20trend%20
Is there a way to automate those actions via a script ?
If so do we have acces to the same parameters listed in the link (Fixed interval , exclude gaps etc...)
Are there alternative methods to retrieve trending data ?
Thank you,
Best regards,
Alexandre
Alexandre Bonnet [DevOps Advocate] Selected answer as best 20th August 2025
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 5th June 2025 0 Comments
Hi Alexandre,
You can consider setting up an offload database. Please refer to 'Setting up an offload database' in DataMiner Docs for more information on setup and configuration.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 5th June 2025
