Is it possible to edit DataMiner visual overviews with other tools than Microsoft Visio?
Solved2.74K views16th September 2020Visio Visual Overview
7
João Pereira [SLC]130 16th September 2020 0 Comments
There are other tools that enable a user to edit traditional Visio drawings; however, is it possible to edit Visio drawings used as visual overviews in DataMiner, for example using the Skyline stencils and Advanced Editing options, with these other tools?
Thank you for your help.
João Pereira [SLC] Selected answer as best 16th September 2020
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 16th September 2020 0 Comments
Most of the Visio alternatives I have seen are limited to diagram/flowchart drawing, while Visio has a lot more possibilities, and is highly extensible with new shapes. You can find a lot of stencils around the web, while some of the alternatives are limited to an included set of shapes.
Next to that, some of the alternatives only allow creating a 'static' diagram, and have poor or no support for shape data. As all of the configuration for use in DataMiner is done using shape data, such alternatives cannot be used to create or edit drawings for use in DataMiner.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 16th September 2020
