Is it possible to display values ​​in bps using standard MIBs?
946 views29th June 2026timeofday
Hiroaysu Nakajima84 29th June 2026 0 Comments
Hello,
Is it possible to display bps by polling IN Octets and OUT Octets every 10 seconds and calculating the difference from the values ​​recorded 10 seconds prior, using the formula `bps = (difference in octets / 10 sec) * 8 bits`?
Alternatively, please let me know if there are any example connectors available on your website.
Thanks.
Hiroaysu Nakajima Answered question 29th June 2026
Hiroaysu Nakajima84 Posted 29th June 2026 0 Comments
Thanks, Pedro.
I’ll check things out tomorrow based on the information you provided.
By the way, I made a typo and entered "Hiroaysu," but the correct spelling is "Hiroyasu." I can't change the account name, so I'm leaving it as is.
