Is it possible to build an node edge graph where node are rows of a table?
Solved1.72K views13th July 2023Dashboards
Bruno Sousa [DevOps Member]669 23rd November 2021 0 Comments
Hello
I was trying to implement a node edge graph to visualize switches and connections from DCNM driver.
For this case I am using
  1. the table for the switches as nodes
  2. the table for the interfaces with information for the edges
Although I can draw the graph, the parameters for each node and edge appear as "not initialized"
Can you help understand what can be happening?
Thank you.
Best regards
Bruno Sousa
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 23rd November 2021 3 Comments
Hi Bruno,
This case should be supported I believe, maybe we can move forward via a collaboration task, so we can investigate at your end?
Bruno Sousa [DevOps Member] commented 23rd November 2021
Ok for me.
How is the task scheduled…?
Thank you.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 25th November 2021
Hi Bruno.
Not sure if you are familiar with collaboration yet. There is a nice video on that matter here: https://community.dataminer.services/lessons/project-collaboration/?hilite=collaboration
The part about creating a task starts around 13:40
You can assign the task to me, I’ll pass it on to the squad that can do the investigation. Please let me know if you succeeded in creating and assigning the task.
Bruno Nogueira [SLC] commented 26th November 2021
Hey Bruno,
I’ve created task https://collaboration.dataminer.services/task/172216 and I’ll immediately start investigating. Will share some feedback soon on this.
Cheers!
