Is it possible to automatically group alarms based on element or alarm properties?
Solved2.40K views11th July 2023
Dennis Dreesen [SLC] [DevOps Advocate]642 25th March 2022 0 Comments
One of our users reached out because they would automatically like to group alarms together that are related to the same location (ie site). This site is mentioned as a property. Is it possible to do so? How can I do this? Does this functionality belong to the core DataMiner software?
Thanks in advance,
Dennis
Wouter Bogaert [SLC] [DevOps Enabler]1.17K Posted 25th March 2022 0 Comments
Hi Dennis,
This is possible yes.
In order to do this, you should first make sure the property is added as a column in the alarm console.
Next you need to disable the option Automatically group according to arrangement
After that you can right-click any column header and select Group by this field
In my example I want to group by the OS of my servers.
The result is this:
I hope this is what you're looking for?
Wouter Bogaert [SLC] [DevOps Enabler] Edited answer 25th March 2022
You are viewing 1 out of 5 answers, click here to view all answers.
