Is It Possible to Auto-Switch Icons Based on Trending Data?
544 views18th December 2025grid grid component low code app
8
Tarik Kahric [SLC] [DevOps Member]174 9th December 2025 0 Comments
Is there a way to dynamically change the icon (e.g., arrow up/down) based on whether the value is trending upward or downward in the low code app? If yes, what condition or binding should I use to determine the trend direction?
Image attached:
Steve Purcell [SLC] [DevOps Advocate] Answered question 18th December 2025
Steve Purcell [SLC] [DevOps Advocate]2.37K Posted 18th December 2025 0 Comments
Hi Tarik,
You could try using the Get Behavioral Change Event (Get behavioral change events | DataMiner Docs) which indicates 'Increase' and 'Change Type', then conditionally show the corresponding shape.   This method would rely on the Anomaly Detection (Behavioral anomaly detection | DataMiner Docs) so would not be present for every parameter.
I believe the better solution would be to extend the connector and add a parameter to allow for change direction.  The connector is aware of current and previous value which is needed to perform the change detection.  Then use this parameter in the LCA or Dashboard to conditionally show the corresponding shape.
