Is it possible to amend the DMA id of an element after migrating it to another DMA
Solved1.50K views3rd October 2023
Paul Lee [DevOps Member]715 3rd October 2023 0 Comments
I have migrated an element to another DMA within a DMS by using the migration feature (Agents – status – Migrate).
The element has been migrated successfully and updated the host id and the dma name accordingly but the id property has not been updated i.e. it’s still showing the old dmaId/elementId as the Id which could potentially lead to a confusion or a failure.
Therefore, I am wondering how the ID can be updated so that it shows the correct information about where the element is hosted. Could anyone please advise? Thanks.
Paul
Paul Lee [DevOps Member] Selected answer as best 3rd October 2023
Bert Vandenberghe [SLC] [DevOps Enabler]10.11K Posted 3rd October 2023 0 Comments
Hi Paul,
This is by design. The DMA ID/Element ID combo is actually using the DMA ID of the DMA you created the element on. If you later on move the element to another DMA this DMA ID/Element ID will always remain the same. This is to avoid problems because various things like e.g. DMS Filters, Visio files, Correlation rules, etc. could have a reference to this ID. Therefore, you never want this ID to change. The name of an element and the hosting DMA can change, but this original DMA ID/Element ID combo will never change and cannot be changed (unless you would manually start tweaking configuration).
This feature is actually called DELT or DataMiner Element Location Transparency.
Bert
