Is it possible to add a Parameter Key into a dashboard alarm filter?
Solved701 views7th June 2025alarm filters Dashboards
Regan Hughes [DevOps Member]108 23rd May 2025 2 Comments
Hi team, we're creating a dashboard with some alarm filters in it, and we would like to include the Parameter Key column, that is visible in Cube.  However this option doesn't seem to be available in the
Dashboard > Settings > General > Columns section
We want this because our alarm parameter descriptions are a little long, and the parameter keys are more concise for easier visibility.
Thanks for your help.
Regan Hughes [DevOps Member] Selected answer as best 7th June 2025
Koen Cools [SLC] [DevOps Member] commented 23rd May 2025
Hi Regan
Unfortunately, I have to confirm that this is indeed today not possible. There is no specific reason why we don’t have yet this column available, except that we started to make the most popular columns available. GQI can be used to get this information, but you will miss then other important features. Depends a little bit what you want to do with the alarm list.
Regards, Koen
Regan Hughes [DevOps Member] commented 23rd May 2025
Thanks Koen, appreciate the response. GQI in a low code app might be the way to go. We’ll look into that. Thanks again.
Regan
Marieke Goethals [SLC] [DevOps Catalyst]7.17K Posted 6th June 2025 0 Comments
Hi Regan,
Do you still need further follow-up on this question? If not, could you select this answer to indicate that it can be closed?
