Is it possible to add a device Web UI DVE?
Solved1.88K views5th June 2023DVE embedded web GUI
Diogo Silva [SLC] [DevOps Member]214 19th May 2023 0 Comments
An OMS driver that i am working on is spinning off DVEs that are based on real modems monitored by this system.
The customer is requesting for the device specific Web UI to be included int the exported DVEs.
Is this possible and if so, how can i do it?
Many thanks.
Diogo Silva [SLC] [DevOps Member] Selected answer as best 5th June 2023
Ben Vandenberghe [SLC] [DevOps Advocate]9.73K Posted 19th May 2023 2 Comments
(starting a new response to include a capture)
Isn't this what you are looking for:
Available here:  Export rules | DataMiner Docs
Diogo Silva [SLC] [DevOps Member] commented 19th May 2023
That might be indeed what i was looking for!
Many thanks.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 19th May 2023
Super – let us know if it worked out for your use case. The devil is always in the details.
