Is changing of Element Logging Levels Logged?
Solved1.10K views11th September 2025logging logging level
Dave Keller [DevOps Enabler]1.95K 11th April 2025 0 Comments
Is changing the logging levels of an Element logged anywhere apart from in the log file?
If changing the logging level results in a lot of messages, the log message stating when the logging level was changed is lost.
Thanks
Catarina Grilo [SLC] [DevOps Enabler]3.03K Posted 11th April 2025 0 Comments
Hi Dave,
I believe this change is only reflected in the log file of the element itself. There is no corresponding information event, for example.
However, if you go to Cube > System Center > Logging > Elements, you'll see the configured log level displayed next to each element's name. That makes it easy to quickly identify which elements are set to a higher log level.
Catarina Grilo [SLC] [DevOps Enabler] Answered question 11th April 2025
