Is a VM running Cassandra with only 16GB for a staging agent sufficient enough?
Solved1.14K views7th July 2023
7
Dominik Kosteletzky [DevOps Advocate]773 1st March 2023 0 Comments
Usually for Cassandra these options should be set in jvm-server.options:
-Xms16G
-Xmx16G
...but with these settings the Cassandra service dies on a VM with 16G RAM total.
Now can this be lowerd for a staging agent or is it really a must to use 32GB RAM on the VM?
Dominik Kosteletzky [DevOps Advocate]773 Posted 1st March 2023 0 Comments
Thank you, Ive!
I try:
-Xms8G
-Xmx8G
Dominik Kosteletzky [DevOps Advocate] Answered question 1st March 2023
