Investigating running processes
Solved3.47K views25th January 2024Process usage SLPort SLProtocol
Garry Metcalfe [DevOps Member]156 4th September 2023 0 Comments
I am investigating some issues with the invocation of the correct processes between the A&B leg of a DMA pair. However, I don't actually have a reference of exactly what should be running. I have 5 slprotocol and 5 slport running on a single DMA as well, which seems strange to me.
If anyone had such a reference guide, I would be very grateful
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 25th January 2024
Garry Metcalfe [DevOps Member]156 Posted 4th September 2023 1 Comment
Hi Floris,
Thanks for the speedy response, and useful info. I have looked at the documentation, and as I then understand, I should see each of these running on the live DMA, (with some as mentioned running multiple times in a pool depending on DMA configuration).
For the offline DMA what subset of these processes should I see, or is it better to ask, which processes should I not see?
Floris Cockaerts [SLC] [DevOps Member] commented 19th October 2023
Hi Garry, the 3 SLSNMPManager instances should always be running. SLProtocol and SLPort will be started as elements are started during a failover switch. However, after the main agent takes over again from the failover agent, these processes are not explicitly stopped.
Also, apologies for the slow response, dojo users in general are not notified of new posts on a question that they reply to, only comments trigger a notification. So if you post a new answer, you may want to post a comment too to get a specific user’s attention.
