Interfacing With Billing System
Solved2.15K views27th May 2021
Jordy Bekaert [SLC] [DevOps Advocate]2.24K 27th May 2021 0 Comments
I have a question regarding interfacing some kind of billing system with Dataminer. My understanding is that the billing system would want to extract some information from Dataminer.
What would be the interface to use? Is there a query interface to the database, or do you extract information with Dataminer and generate an xml or excel report?
What would be the possibilities and recommended solution?
Jordy Bekaert [SLC] [DevOps Advocate] Selected answer as best 27th May 2021
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 27th May 2021 0 Comments
Hi Jordy, see the following page for an overview of the possible APIs to extract data from DataMiner: https://help.dataminer.services/dataminer/#t=DataMinerUserGuide%2Fpart_3%2FDataminerSystems%2FDataMiner_interfaces.htm.
Which method to use exactly depends on the possibilities of the system that connects to it. I think the webservices is the recommended way if it's supported.
Tom Waterbley [SLC] [DevOps Enabler] Edited answer 27th May 2021
