InterApp communication between SLAutomation and SLProtocol using SLC.Lib.Common NuGet
Solved3.14K views25th May 2022InterApp SLAutomation SLProtocol
Jason Pitteman [SLC] [DevOps Member]556 24th May 2022 0 Comments
We have a protocol that implements several InterApp calls. Both the protocol and the automation script are using Nuget SLC.Lib.Common version 1.2.2.2 in order to use InterApp calls. However when sending the InterApp call from the Automation script to the protocol we can see that the protocol processes the request correctly and it sets the response on the correct parameter 9000001. But the automation script does not receive the response and it times out.
Here's the code snippet:
Would anyone have a clue of what is going on?
Thanks,
Jason
Jan Staelens [SLC] [DevOps Advocate] Answered question 25th May 2022
Avatar photo
Jan Staelens [SLC] [DevOps Advocate]969 Posted 25th May 2022 1 Comment
Be aware, the marked Answer is a workaround that can still fail in situations.
Took a deeper look and found a bug in the class library where the Answer from Thijs will still break if you have more than one List<T> in your KnownTypes.
We're looking into a fix for this in the upcoming weeks. (from the time of this comment)
Details:
We perform a .Name on the known types to include in the json. For a List<T> this always returns List without the internal type. If there's more than one List the code notices  .Name is not unique so it falls back to using .FullName.
FullName according to .NET Documentation should only every return the Namespace + Class and leave out the Assembly (and it does for most things). But there's a bug in NET where if the type is a collection the type inside the collection will include the Assembly and not just the namespace + class. This causes the problems with deserialization for Lists and collections.
We're looking into using other calls or filtering out the assemblies.
Jan Staelens [SLC] [DevOps Advocate] Posted new comment 10th June 2022
Avatar photo
Jan Staelens [SLC] [DevOps Advocate] commented 10th June 2022
This has now been fixed.
Using class library version
>1.2.2.3 or >1.1.4.3
