InterApp communication between SLAutomation and SLProtocol using SLC.Lib.Common NuGet
Solved2.93K views25th May 2022InterApp SLAutomation SLProtocol
Jason Pitteman [SLC] [DevOps Member]556 24th May 2022 0 Comments
We have a protocol that implements several InterApp calls. Both the protocol and the automation script are using Nuget SLC.Lib.Common version 1.2.2.2 in order to use InterApp calls. However when sending the InterApp call from the Automation script to the protocol we can see that the protocol processes the request correctly and it sets the response on the correct parameter 9000001. But the automation script does not receive the response and it times out.
Here's the code snippet:
Would anyone have a clue of what is going on?
Thanks,
Jason
Jan Staelens [SLC] [DevOps Advocate] Answered question 25th May 2022
João Severino [SLC] [DevOps Enabler]14.71K Posted 24th May 2022 0 Comments
Hi Jason
A couple of things I would check in the implementation are
  1. The protocol is assigning the correct Guid to the response message in the executor (response Guid must match the message Guid)
  2. The same serializer is being used by both sides of the communication
These are some things I overlooked in the past and that could help
João Severino [SLC] [DevOps Enabler] Answered question 24th May 2022
