Installing Fresh DMA
Solved1.17K views7th September 2023
Ashwini Gangadharan [DevOps Member]446 11th May 2023 0 Comments
We have our Production cluster up and running. I am installing a new standalone instance for staging environment. I have installed the Main package, upgrade packages and the latest SRM package. Let me know what to be proceeded to import the drivers, protocols and packages from production to my staging environment.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th September 2023
Srikanth Mandava [SLC] [DevOps Advocate]936 Posted 12th May 2023 2 Comments
Ashwini
If you are simply trying to import the drivers/protocols then you have couple of options.
  1. Getting hold of the driver package files again from Skyline, contact your TAM or techsupport@skyline.be and installing these drivers on your staging environment.
  2. You can also copy protocol.xml files from the production to the staging environment, and use instructions at Adding a protocol or protocol version to your DataMiner System | DataMiner Docs .
If your staging DMA is cloud connected, then use instructions at Deploying a DataMiner connector to your system | DataMiner Docs .
Hope it helps. Thanks.
Ashwini Gangadharan [DevOps Member] commented 5th June 2023
I am done with the protocols. Can you guide through further steps.
Srikanth Mandava [SLC] [DevOps Advocate] commented 6th July 2023
Ashwini, lost track of this thread. Apologies. If you are looking for the information on installing SRM then please see the documentation at https://docs.dataminer.services/user-guide/Standard_Apps/SRM/srm_getting_started/deploying_srm.html .
Thanks.
