installation procedure first two tiers of SRM
Solved1.96K views12th September 2022SRM
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 7th September 2022 0 Comments
What is the installation procedure for the Resource Scheduling and the Resource Automation for SRM?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 12th September 2022
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 9th September 2022 0 Comments
Jeroen,
User manual now contains information on how to get started with Resource Automation and Resource Scheduling
