installation procedure first two tiers of SRM
Solved1.52K views12th September 2022SRM
Jeroen Geldhof [SLC] [DevOps Enabler]5.50K 7th September 2022 0 Comments
What is the installation procedure for the Resource Scheduling and the Resource Automation for SRM?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 12th September 2022
Emmanuel Dal [SLC] [DevOps Member]4.63K Posted 7th September 2022 2 Comments
Jeroen,
You will have to create a Booking Manager Element and set the 'Booking Application Context' parameter to 'Resource Scheduling'.
Then, you will need to build/extend UIs to trigger these actions. You can start from examples that are available on Ziine.
Emmanuel Dal [SLC] [DevOps Member] Posted new comment 7th September 2022
Jeroen Geldhof [SLC] [DevOps Enabler] commented 7th September 2022
Is there documentation for partners to set this up?
Emmanuel Dal [SLC] [DevOps Member] commented 7th September 2022
This is work in progress.
Doc already contains information on how to create a function from scratch ( https://docs.dataminer.services/user-guide/Standard_Apps/SRM/srm_getting_started/implementing_function_srm.html ) and how to use it with Service Orchestration.
It will be extended with Resource Automation, Resource Scheduling and Resource Orchestration
