Include timeout disabled by default for a secondary connection?
Solved2.05K views5th January 2022SNMP timeout traps
Alex Johnson [SLC] [DevOps Advocate]921 3rd January 2022 0 Comments
Hi all,
I'm trying to add a secondary snmp connection for traps, but would like to have the include timeout option disabled by default:
I know in port settings you have the two options to disable element timeout time/timeout time, but that just disables the ability to edit the times:
I can't seem to find a way to have "include timeout" be set to disabled by default. Is this possible? I need the snmp connection for traps, but it keeps putting the element in timeout when I add it (because the device doesn't actually have polling). Any help would be greatly appreciated!
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 5th January 2022
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 4th January 2022 1 Comment
Hi Alex,
If the connection is only used for traps then it's suprising to me that this would cause your element to go into timeout. If you are never sending a request using this connection, then there can't be any timeout. Are you sure you don't have any polling using this connection?
As far as I'm aware, it's not possible to disable the "Include Timeout" via the PortSettings in the protocol.
Alex Johnson [SLC] [DevOps Advocate] Posted new comment 5th January 2022
Alex Johnson [SLC] [DevOps Advocate] commented 5th January 2022
You’re right. It ended up actually being the other connection that was putting it into timeout. My mistake!
