In Low code application is there any way wherein we can have drag and drop functionality?
Solved1.84K views22nd November 2024#automationscripts #lowcodeapplication Automation DataMiner
Apurva Tandon [DevOps Member]1.73K 24th July 2024 2 Comments
I have a scenario wherein I have two lists:
List 1: 1, 2
List 2: a,b,c,d
I will be showing these as a list on side in application and there will be UI wherein the user will drag drop
like
Rectangular Box 1:  a,  b,  d
Rectangular Box 2:  c
Boxes will be same as number of items in list 1
And post this we need to send this information back to some 3rd party API in JSON that was allocation.
How this thing can be achieved?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd November 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 19th September 2024
I see that this question has been inactive for some time. Do you still need help with this? If yes, could provide the additional information Sebastiaan asked? Or if not, could you select the answer (using the ✓ icon) to indicate that the question is resolved?
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 7th August 2024 0 Comments
Hi Apurva,
Currently, we don't have any functionality that allows drag-and-drop within Low-Code Apps.
However, I'm happy to explore alternatives for your use case. To do so, I will need additional details about the solution you are developing (e.g., what is being built, what will be drag-dropped, etc.).
Additionally, we can gauge the community's interest in this feature by creating a feature request.
