In an automation script: is engine.Sleep(30000) blocking? Safe or best avoided?
Solved641 views8th September 2026automation engine Automation script automation scripts
7
Stephen Goode [DevOps Member]154 8th September 2026 0 Comments
Is using engine.Sleep in the context of an automation script blocking outside of the individual script run, i.e. would this 30 second sleep lock the UI thread, block other scripts from running, or result in wider performance degradation within the 30 seconds ?
Stephen Goode [DevOps Member] Selected answer as best 8th September 2026
Tom Waterbley [SLC] [DevOps Enabler]10.36K Posted 8th September 2026 1 Comment
Hi Stephen, engine.Sleep(30000) only pauses that individual script run for 30 seconds. It should not generally block unrelated automation scripts or other threads from running.
Stephen Goode [DevOps Member] Posted new comment 8th September 2026
Stephen Goode [DevOps Member] commented 8th September 2026
Hi Tom, thank you
