In Alarm Console, how do we filter out blank cells?
Solved3.85K views10th September 2021Alarm Console alarm filters
Steve Purcell [SLC] [DevOps Advocate]2.63K 9th September 2021 0 Comments
We want to be able to use the Alarm Console filter (services:) to only show alerts where the services field is populated.  We have tried different entries (services:!"", services:*), however, the alarms with the Services column blanks continue to appear.  Is there a way to set the Alarm Console filter to filter out blanks?
bruno santos [SLC] [DevOps Advocate] Answered question 10th September 2021
bruno santos [SLC] [DevOps Advocate]1.30K Posted 10th September 2021 0 Comments
It seems you can't do it on the quick search bar, but creating a new tab with a custom filter allows you to use regex. see the screenshot below to filter out empty services or any other field
bruno santos [SLC] [DevOps Advocate] Edited answer 10th September 2021
