Importing exported table csv into a element using debug protocol
Solved1.10K views2nd January 2024Simulation tool tools
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 12th December 2023 0 Comments
On a table of an element in Cube I exported all rows to a csv.
However I’m wondering, when using the Protocol Debug tool if there’s a way already to import these csv’s into the debug protocol ?
I do know the Copy Element Data scripts exists, but I’m only interested in a subset of tables, not the entire element.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd January 2024
João Severino [SLC] [DevOps Enabler]14.52K Posted 27th December 2023 0 Comments
Hi Tim,
I believe the current set of features of the Protocol Debug tool is more intended for manipulating the protocol XML and creating a debug version of it where you can then perform some actions, so I do not believe it is currently capable of achieving what you are after.
I believe the best option for your use case is to use the Copy Element Data scripts.
It is currently designed to export/import everything but if you manipulate the resulting file of the Export script to only contain the tables you are interested in, you can then use it to import in your new element.
Feel free to make a new feature request here Feature Suggestions so that an enhancement can be evaluated for those tools.
