Impact of running Low code apps on a DMA that also has Cube based processing.
245 views4th February 2026low code apps MediaOps performance
Mark Smith92 3rd February 2026 0 Comments
What is the impact of running Low code apps or one of the Standard Solutions (such as MediaOps) on a DMA that has Cube based functions running (e.g. element monitoring with device and service alarms). Is it ok to mix them up or best to allocate a DMA for low Code apps within a cluster.
Gelber Mahecha [SLC] [DevOps Enabler] Answered question 4th February 2026
Gelber Mahecha [SLC] [DevOps Enabler]1.97K Posted 4th February 2026 0 Comments
Hi Mark,
This is about the current and expected use of the resources within your DMS. Usually, LCAs should run on the same servers as the main DataMiner software, as long as there are enough resources for everything.
Check how your resources are being used and, if needed, change the setup on your DataMiner servers. This way, you will have enough resources when you add new features from the LCAs. If you are not sure, you can always ask your Technical Account Manager to look at your situation.
Finally, running the Cube client directly on a DataMiner agent is possible, but you should avoid it, as it may consume resources that could be better used for core functions and LCAs.
