IIS warning after setting up https
Solved14.68K views7th July 2023HTTPS IIS
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K 6th July 2023 0 Comments
I just setup HTTPS on my local agent by following the docs. Everything is functioning as expected.
When looking on the "Default Web Site" in IIS I get an alert saying:
No default SSL site has been created. To support browsers without SNI capabilities, it is recommended to create a default SSL site.
I understand this mostly impacts old browsers, but I wonder if this will impact any DataMiner functionality.
Wim Bruynooghe [SLC] [DevOps Advocate] Answered question 7th July 2023
Wim Bruynooghe [SLC] [DevOps Advocate]6.76K Posted 7th July 2023 0 Comments
You only need SNI support in case you want your DMA accessible through multiple hostnames (FQDN) from the same IP with HTTPS using separate certificates (you could also host another website on the same server this way). Without SNI, the secure connection already gets created before IIS knows which hostname you want to access, so it can't know which certificate it should use, in this case it takes the default (where require SNI is unchecked). If this certificate then doesn't match with the FQDN that the user specified, the secure connection will fail. Without SNI, you need to use a separate IP address per website/certificate.
If you only have one website with one certificate, then you don't need SNI at alll and you can just uncheck it. Normally this is the case with a DataMiner Agent.
Wim Bruynooghe [SLC] [DevOps Advocate] Edited answer 7th July 2023
