IAS – TextBox “IsReadOnly = true” works fine in low code app but it’s not working in the Cube
Solved1.86K views11th July 2024IAS
Vincenzo Converso [DevOps Member]92 11th July 2024 0 Comments
I was making this IAS to display some information(I will add it as a custom action on the alarm context menu), and i need that the fields “Title” and “Instruction” are on multiline and read only so i used the TextBox object. In a low code app it’s working fine but when i trigger the IAS from the cube it’s not read-only.
Interactive Automation script Toolking version: 8.0.4
Dataminer Version: 10.4.5.0-14239
Code:
private void InitDialogWidgets()
TitleLabel = new TextBox { IsReadOnly = true, Height = 50, Width = 1200, MaxHeight = 1000, IsMultiline = true };
MsgKeyLabel = new Label { MaxWidth = 1200};
DescriptionLabel = new Label();
SeverityLabel = new Label();
CategoryLabel = new Label();
NodeLabel = new Label();
ObjectLabel = new Label();
ApplicationLabel = new Label();
InstructionLabel = new TextBox { IsReadOnly = true, Height=90, Width= 1200, MaxHeight = 1000, IsMultiline = true};
HintLabel = new Label();
CustomAttributeLabel = new Label();
DuplicateCountLabel = new Label();
LastUpdateLabel = new Label();
OwnerLabel = new Label();
Vincenzo Converso [DevOps Member] Selected answer as best 11th July 2024
Robin Meurisse [SLC] [DevOps Advocate]1.51K Posted 11th July 2024 2 Comments
Hi Vincenzo,
Could you try setting the TextBox Property ‘IsEnabled’ to false as well?
Property IsEnabled | DataMiner Docs
That should result in the same behaviour in Cube as you now see on the Low Code App. The widget will then be greyed out and not be editable.
Hope this helps.
Kind regards,
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Posted new comment 11th July 2024
Vincenzo Converso [DevOps Member] commented 11th July 2024
thank you, now is working also in the cube
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 11th July 2024
Just want to highlight that disabling is different from read-only. Read-only still allows copying the text, for instance, while disabling prevents all user interaction with the control altogether.
