IAS – Clearing values on applications
Solved2.20K views25th April 2022Application dropdown IAS
Blake Smethers [SLC] [DevOps Advocate]1.28K 22nd April 2022 0 Comments
I have an interactive automation script that uses a button to clear a selection of dropdowns. When I execute that via cube, the data is cleared properly:
When I use the Application, the drop down does not clear:
Is there a special way to clear the drop downs in an IAS?
Thanks in advance for any information.
Blake Smethers [SLC] [DevOps Advocate] Selected answer as best 25th April 2022
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 25th April 2022 1 Comment
Hi Blake,
This looks like an inconsistency to me and is most likely a software issue.
It's hard to determine which one of the two is the outlier based on the video alone. I suggest to create a task for this so it can be investigated.
Blake Smethers [SLC] [DevOps Advocate] commented 25th April 2022
Hi Sebastiaan, will do. I didn’t think about how the gif will make it seem like the clear button does work when the gif starts over again.
Thanks!
