Hyperlinks – Is it possible to execute two (or more?) actions
Solved2.18K views12th August 2020Alarm Console hyperlinks
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.53K 12th August 2020 0 Comments
Custom commands can be added to the shortcut menu of the Alarm Console by defining them in the Hyperlinks.xml file.
Is it possible to have one custom command (one HyperLink tag) which executes two actions:
  1. first, execute a script
  2. secondly, open a specific page on the Visio?
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] Selected answer as best 12th August 2020
Lander Vanhaverbeke [SLC] [DevOps Member]1.00K Posted 12th August 2020 0 Comments
Currently this is not possible: a hyperlink executes one action. I would advise to add these actions as separate hyperlinks.
Depending on what the script does exactly, you could also create a hyperlink to open the specific Visio page, and add a button to the Visio to execute the desired script.
