HyperLink – Using Placeholders on type OpenElement and OpenService
Solved2.08K views13th July 2021Alarm Console alarm properties Cube DataMiner Cube hyperlinks
David Pernes [SLC]90 12th July 2021 0 Comments
I'd like to know if Hyperlinks support placeholder data for HyperLinks of type "OpenElement" and "OpenService" with Alarm Property placeholder.
I'm using custom properties on an Alarm and making links to specific elements based on those properties this way a user could right click an alarm and be automatically transported to correct service / Booking.
My Alarms seem to have proper Properties as seen below:
This is my HyperLinks.xml file:
Detected difficulties:
  1. Open Element works fine whenever an explicitly typed DMAID/EID is provided to the xml. The Property "Booking Manager Element ID" holds the exact same DMAID/EID combination as the explicitly type, are these Placeholders supported on Hyperlinks of type OpenElement ?
  2. Open Service does not show up whenever i right click an Alarm
I based myself on DataMiner Help but could not detect any further information regards to this feature,
Any advice on how to these Open Element and Open Service Dynamic ?
DMA v : 10.1.7.0-10523
Client version : 10.1.2121.1568-b9e7f229
David Pernes [SLC] Selected answer as best 13th July 2021
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 12th July 2021 0 Comments
Hi David,
As far as I know the only placeholders supported are [EID] for openelement and [SID] for openservice (including specific pages). There is an internal task requesting this feature [DCP110657].
Regarding the behavior with openservice, I am not able to reproduce it. Please find below an example of Hyperlink.xml and the result:
Hyperlink.xml:
<HyperLinks xmlns="http://www.skyline.be/config/hyperlinks">
<HyperLink
id="1"
version="2"
name="Open SLC Service"
menu="Custom Actions"
type="openservice">[SID]
</HyperLink>
<HyperLink
id="2"
version="2"
name="Open SLC Element"
type="openelement">[EID] </HyperLink>
</HyperLinks>
Result:
In this case my alarm is linked to element TEST_ELEMENT_01. This element is part of TEST_SERVICE_01 and TEST_SERVICE_02 (that is the reason two services are displayed in the menu)
Miguel Obregon [SLC] [DevOps Catalyst] Edited answer 12th July 2021
