How to validate if my system is using SNMP++ instead of WinSNMP?
Solved1.11K views23rd January 2025SNMP SNMP agent SNMP Requests
Edson Alfaro [SLC] [DevOps Advocate]1.76K 20th January 2025 0 Comments
Hi all,
A recent upgrade happened to a system (10.4.0 CU9) and the soft-launch option for SnmpPollingSnmpPlusPlusOnly was enabled.
Is it possible to validate that the system is effectively using SNMP++ instead of WinSNMP?
Thanks.
Edson Alfaro [SLC] [DevOps Advocate] Selected answer as best 23rd January 2025
Jeroen Neyt [SLC] [DevOps Advocate]2.61K Posted 20th January 2025 1 Comment
At first sight it does not look something that gets logged in the SNMP related logging nor can be deduced based on other logging.
However, we can guarantee that if SLNet correctly shows the option as enabled that the SLSNMPManager process is correctly configured and will be effectively not using WinSNMP anymore to do the SNMP polling.
You can validate this by using the SLNetClientTest to connect to the agent and then send the GetSoftLaunchConfigMessage which will list all configured soft-launch options.
Edson Alfaro [SLC] [DevOps Advocate] commented 23rd January 2025
Thanks Jeroen, I tried that and worked!
