How to use NotifyType 444 NT_ASSIGN_ELEMENT_VDX
Solved2.23K views28th June 2024NotifyType NT_ASSIGN_ELEMENT_VDX protocol Visio
Guilherme Gaspar [SLC] [DevOps Member]549 27th June 2024 0 Comments
The goal is to assign a visio file (.vdsx) to an element, via protocol.
I found the NotifyType(444) /*NT_ASSIGN_ELEMENT_VDX */
...which appears to do what I want, but I cannot find how to make it work.
List of NotifyTypes
Guilherme Gaspar [SLC] [DevOps Member] Selected answer as best 28th June 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 28th June 2024 1 Comment
Hi Guilherme,
Following up on the comment you made here to Miguel's answer, you should be able to use
  1. CreateElementFileMessage call to create the visio file properly (named Element_[dmaId]_[elemId].vdsx)
  2. GetInfoMessage with the Type VdxFileChangeInfo to retrieve the last change time if you want to double check it has been updated (see screenshot at the bottom of the answer)
  3. UpdateElementActiveVisioMessage to set the visio to the element
Guilherme Gaspar [SLC] [DevOps Member] Posted new comment 28th June 2024
Guilherme Gaspar [SLC] [DevOps Member] commented 28th June 2024
That’s it!
