how to use matrix input Label, output Label — “Visio”
Solved1.98K views19th July 2023
HyungMo Jung20 6th April 2021 2 Comments
  1. I’d like to mark the checked input label and output label of the attached picture on “Visio”.
  2. Please explain the required shape data field configuration.
Jamie Stutz [SLC] [DevOps Member] commented 6th April 2021
Hi HyungMo! Would you be able to provide the Protocol and it’s version number you are working with? We have several different matrix drivers and depending on which you are using, the approach may differ. Also the version of DataMiner you are on might also be useful. Thanks!
HyungMo Jung commented 7th April 2021
Protocol : Leitch Matrix Serial 1.1.0.3
DMA : 10.0.13
Tiago Bento [SLC]20 Posted 9th April 2021 0 Comments
Hi HyungMo! For your specific use case, the most straightforward way is maybe to use the router control app:
This will allow you to create a custom router control in which you can define your matrix. This router control can then be embedded in Visio. Documentation on how to embed the router control in the Visual Overview can be found in: Embedding a router control component
We also have a video showing how this integration with Visio can be performed:
Router control – introduction
Feel free to reach back out if you have any other concerns.
