how to use engine in Ad hoc data source
Solved1.12K views27th August 2024Adhoc data source
Bernard Pichot [SLC] [DevOps Advocate]1.32K 14th June 2024 0 Comments
is it possible to use Engine engine available in automation script in an Ad Hoc data source ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th August 2024
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 14th June 2024 0 Comments
Hi Bernard,
The engine object is only available in actual automation scripts. In GQI adhoc data sources and custom operators this is not available.
However, there is the possibility to send SLNet messages to retrieve data from the DMS. This is explained here: https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/GQI/Extensions/Ad_hoc_data/Ad_hoc_Tutorials_GQIDMS.html
