How to update card variable from an Automation script?
Solved1.81K views16th August 2021Automation variables Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.08K 16th August 2021 0 Comments
I have an automation script in which I use method AddOrUpdateScriptOutput to update variable myValue on my visual
However, I notice that only the session variable is updated after pushing the Test button.
My button in Visio is configured as follow:
Is it possible that my card variable is updated instead?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 16th August 2021
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 16th August 2021 0 Comments
Hi Jens,
you should set the scope/context of your variable onto the shape data.
In your case, you have to set 'cardvariable' in the Options.
FYI: I've updated the RN (27895) and contacted Documentation.
Matthias Declerck [SLC] [DevOps Advocate] Edited answer 16th August 2021
