How to turn a suggestion event into an alarm using a correlation rule?
Solved4.32K views15th September 2021augmented operations Correlation
Thomas Gunkel [SLC] [DevOps Enabler]1.25K 14th September 2021 0 Comments
DataMiner supports suggestion events, but not all suggestion event types can be turned into an alarm, for example suggestion events for pattern matching.
We tried to create the following correlation rule to create a new alarm for :
  • filter: "Is Element Equal to DMA-65"
  • condition: "Is Source Equal to Suggestion Engine"
  • action: create new alarm with severity Critical
Running the correlation rules only shows alarms created by the suggestion engine, but no suggestion events (where source = suggestion engine as well).
Is there a way to also include suggestion events into the above correlation rule and exclude alarms which are coming from the suggestion engine?
correlation rule & suggestion events (ignored by correlation rule)
alarms created by suggestion engine (not ignored by correlation rule - but should be excluded)
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 15th September 2021
Veerle Ledoux [SLC] [DevOps Advocate]251 Posted 14th September 2021 1 Comment
Hi Thomas,
The suggestion events are created as information events, that is they have severity "Information", and with Source equal to "Suggestion Engine".
In order to allow the correlation rule to be triggered by information events (and hence suggestion events), it seems you will have to select the option "Accept information events".
An extra filter on the severity can help you to distinguish between suggestion events and alarms from the suggestion engine, I hope something like this (on top of your filter on the Suggestion Engine source) might work for you
Thomas Gunkel [SLC] [DevOps Enabler] Posted new comment 15th September 2021
Thomas Gunkel [SLC] [DevOps Enabler] commented 15th September 2021
Thanks Veerle! Accepting information events did the job, now we can turn suggestion events into alarms, thanks!
You are viewing 1 out of 5 answers, click here to view all answers.
