How to turn a suggestion event into an alarm using a correlation rule?
Solved3.83K views15th September 2021augmented operations Correlation
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 14th September 2021 0 Comments
DataMiner supports suggestion events, but not all suggestion event types can be turned into an alarm, for example suggestion events for pattern matching.
We tried to create the following correlation rule to create a new alarm for :
  • filter: "Is Element Equal to DMA-65"
  • condition: "Is Source Equal to Suggestion Engine"
  • action: create new alarm with severity Critical
Running the correlation rules only shows alarms created by the suggestion engine, but no suggestion events (where source = suggestion engine as well).
Is there a way to also include suggestion events into the above correlation rule and exclude alarms which are coming from the suggestion engine?
correlation rule & suggestion events (ignored by correlation rule)
alarms created by suggestion engine (not ignored by correlation rule - but should be excluded)
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 15th September 2021
Thomas Gunkel [SLC] [DevOps Enabler]1.23K Posted 14th September 2021 0 Comments
severity = information
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 14th September 2021
You are viewing 1 out of 5 answers, click here to view all answers.
