How to specify on an SNMP set param what connection to use?
Solved204 views4th February 2026Connector SNMP Connector
Brecht Deconinck [SLC] [DevOps Member]1.32K 4th February 2026 0 Comments
We have an SNMP connector with multiple SNMP connections to poll a failover data-source system.
- SNMP connection 1 -> Primary data-source (main server)
- SNMP connection 2 -> Secondary data-source (backup server)
For a SNMP data source there's a write-only parameter (snmpSet) available to trigger some actions on that particular server.
How can I specify on the snmpSet write param what SNMP connection ID it has to use?
Basically, the snmpSet param for the main server should always use the first SNMP connection.
The snmpSet param for the secondary server should always use the second SNMP connection.
Is there a way we can hard-coded say what connection to use?
Or do we have to use 2 SNMP IPID parameters (dynamic connection approach)?
Brecht Deconinck [SLC] [DevOps Member] Selected answer as best 4th February 2026
Laurens Moutton [SLC] [DevOps Enabler]9.60K Posted 4th February 2026 0 Comments
This can be done similarly like with the snmpSetAndGet, as explained here , by setting options="connection=1" in the Type of the parameter (where 1 is the connection number in this example).
Regards,
