How to set the correct filters when i am using ALARM ID as base parameter
Solved2.22K views17th October 2023
Marian Bacana155 30th May 2023 2 Comments
Hello,
I need some guidance. I am trying to set some filters on alarms so i can get something specific. Below is a capture from the filters window.
I am trying to use the Alarm ID to get exactly what i want.
So, on short, the id of the alarm i want to pick is 4653069. I tried to put this value on Filters column but the alarm does not disappears or appears. If i set the value of filter to *, and i place the ID of the alarm to the severity i want (eg. Critical Hi), i can get the alarm but there is also picking other alarms as well that do not have same ID.
I do not understand how the filter works in these cases. How can i set the alarm id so i can get the desired effect ?
Also, what should i write to the severity columns ? It only accepts a number... but what should i put in?
Thanks!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 17th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 4th July 2023
Hi Marian,
Has Randy’s comment helped you solve this? If not, could you add more information so we can help you further?
Marieke Goethals [SLC] [DevOps Catalyst] commented 17th October 2023
As this question has been inactive for a long time, we will now close it. If you want further assistance, could you post a new question?
Marian Bacana155 Posted 31st May 2023 0 Comments
Hi Miguel,
Honestly you lost me.
Where can i see the display key ? How can i see the raw alarms?
I am pretty sure that the way this works is specific to my equipment. I already asked for additional information over the AppearTV drivers but there is not much.
Any other ideas?
Sorry for keep coming back but i am trying to understand how this alarming part works with AppearTV.
Thank you!
Marian Bacana Answered question 31st May 2023
