how to set default port and respective ip for snmp type( advanced =” http” ) protocol
Solved1.33K views1st October 2024protocol snmpv2 with http
Chirangee lal Verma [DevOps Advocate]555 30th September 2024 0 Comments
I am using SNMP type protocol and where http also included. during element creation i just want to set SNMP device  IP for http device as well and want to set default port as well so that during creation no need to mention those things.
other thing i want to know is it possible to use  these details inside the protocol.
Chirangee lal Verma [DevOps Advocate] Selected answer as best 1st October 2024
Fenta Alemahu [SLC] [DevOps Advocate]1.42K Posted 30th September 2024 3 Comments
Hi Chirangee,
You can set default ports for an SNMP (Main) and HTTP (Secondary) connection in the protocol definition like shown below.
For the IPs, you need to fill them in the element configuration wizard. As far as I am aware, there is no way to set default IPs.
Chirangee lal Verma [DevOps Advocate] commented 30th September 2024
so is their another way to develop this protocol so that the i can use only one ip which work for both snmp and http communication.
Geovanny Galeano [SLC] [DevOps Advocate] commented 30th September 2024
I didn’t fully test but if you try adding the visibleInUi=”false” as part of the PortSettings tag this would make it so that this connection would not show on the element wizard and would use the same IP as the first connection.
You would still have to define the Port as described by Fenta
Chirangee lal Verma [DevOps Advocate] commented 1st October 2024
its working thanks.
