How to set an element property using IDmsElement
Solved1.04K views8th November 2023
Victor Scherpereel [SLC] [DevOps Member]51 8th November 2023 0 Comments
I'm looking for a way to set an element property using an object of type IDmsElement.
Via IDmsElement.Properties I can retrieve an IDmsProperty, but this interface does not allow me to set its value.
Victor Scherpereel [SLC] [DevOps Member] Selected answer as best 8th November 2023
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 8th November 2023 1 Comment
Hi Victor
This has already been answered in this question: Add and Update Element Properties using IDms - DataMiner Dojo
Victor Scherpereel [SLC] [DevOps Member] commented 8th November 2023
Thank you.
Unfortunately my search for “IDmsElement property” did not give the link in your answer as a result.
