How to send SNMP traps from a DMA to a device?
Solved1.50K views17th April 2024SNMP traps
Joshua Lee [SLC] [DevOps Advocate]637 16th April 2024 0 Comments
Since dms.Notify is set to be (or already) obsolete, what is the current suggested method to send a trap from a DMA to a device?
I’ve looked through the Class Library but didn’t find any such methods.
Joshua Lee [SLC] [DevOps Advocate] Selected answer as best 17th April 2024
Pedro Debevere [SLC] [DevOps Enabler]3.45K Posted 16th April 2024 0 Comments
Hi Joshua,
I think there is currently no other way to do it other than using the notify call you mention. The class library indeed currently has no such functionality.
