How to restart DMA via Automation Script
Solved2.37K views14th December 2021agent Automation DMA restart script
Guilherme Gaspar [SLC] [DevOps Member]549 13th December 2021 1 Comment
Is there a way to restart an agent via Automation Script, with a SLNet call perhaps?
Use-case: I want the DMA A to be able to restart DMA B, C and D
Guilherme Gaspar [SLC] [DevOps Member] Selected answer as best 14th December 2021
Miguel Obregon [SLC] [DevOps Catalyst] commented 13th December 2021
Hi Guilherme, please could you elaborate why the DMA A should restart DMA B, C and D programmatically?
Paulo Henriques [SLC] [DevOps Advocate]1.96K Posted 14th December 2021 0 Comments
A possible solution, is to use the command line and issue the batch “DataMiner Restart DataMiner And SLNet.bat” from inside “C:\Skyline DataMiner\Tools”.
Then, you can work on 2nd batch file that would use the PSEXEC from SysInternals in order to execute remotely the 1st batch file on the wanted servers.
This is just an idea.
