How to remove info popup/tooltip from Maps component in a LCA ?
Solved763 views27th May 2025LCA maps popup
Alexandre Bonnet [DevOps Advocate]453 9th April 2025 0 Comments
Hello Dojo,
I’m trying to figure out how to disable or remove the white information popup/tooltip that appears when clicking on locations in the Maps component of a LCA. This white box shows details about places (as you can see in my screenshot. Is there a setting or configuration option to hide these popups completely? It’s interfering with some markers on the map, making it difficult to interact with them properly.
Thanks for your help!
Alexandre Bonnet [DevOps Advocate] Selected answer as best 27th May 2025
Robin Debel [SLC] [DevOps Enabler]2.26K Posted 9th April 2025 1 Comment
Hi Alexandre,
At the moment, it’s not possible to disable this behavior. However, we’ve added a task to implement a setting that will allow users to toggle these points of interest. I’ll ensure an update is shared in this thread as soon as this feature is available.
Kind regards,
Robin
Alexandre Bonnet [DevOps Advocate] commented 9th April 2025
Hello Robin,
Good to know, thank you for the answer !
Best regards,
Alexandre
