How to reference DVE parent element in Visio?
Solved1.68K views4th October 2021DVE Visio
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 4th October 2021 0 Comments
Is there a way to reference the parent element of a DVE, from a Visio drawing assigned to that DVE?
I know workarounds are available, eg by using regular expressions or implementing a DVE parameter which holds the parent element’s id/name, but was wondering if there is a ‘built-in’, reliable way to achieve the same?
Thanks!
Ruben Vandepitte [SLC] [DevOps Advocate] Selected answer as best 4th October 2021
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 4th October 2021 0 Comments
There is no out of the box way to do this. The workarounds you gave are the best way to do it.
