How to read selected data from booking wizard in profileLoadScript?
Solved3.52K views10th December 2020process automation SRM
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K 10th December 2020 0 Comments
How to get the data written by user in wizard in profile load script of an activity running in Process Automation.
The Default instance has the following data:
In the profile load I would like to get the "Stop" value as event type as this is what I selected in the wizard.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 10th December 2020
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 10th December 2020 0 Comments
I might be wrong, but I think Process Automation uses the references of the profile instance and not the value (if it is not a volatile process profile instance).
I think we have access to the following in the profile load script:
  • Volatile Process Profile Instances
  • Process Profile Instance Guid
  • Input Itf Profile Instance
  • Node Profile Instance
Jarno Lernou [SLC] [DevOps Enabler] Answered question 10th December 2020
